We have a set of repeat questions within a survey containing a read-only geopoint location question. The repeat section asks if you wish to record the exact location, if you answer yes the surveyor can then specify the location. If the user selects no OR does not answer the question, the default location is recorded as 0,0.
I would like this to default to the survey start location ${survey_location} if a location is not specified. I have tried numerous approaches and none have worked. What is best practice to resolve this?
Christina
