For the FeatureTable there is an easy way to click on feature on the map and it highlights the table row for the selected feature on the table.
simply use featuretable.enableLayerClick=true
on this example:
ArcGIS API for JavaScript Sandbox
just enter on line 104
myTable.enableLayerClick=true;
and any feature you click on the map, you can see the highlighted row.
Here is my question. The Attribute table that is used in wab, is not declared as FeatureTable. So, to get the highlighted row after you click a feature on map, you will have to compare the evt and the records on the grid, and once a match is made use
