When file names (image,audio etc) are generated from images they display as the FieldName- + UUID + .ext
When the files are written to the "My Survey Attachments" folder they are written as FieldName-YYYYMMDD-Rand(6).ext
Name During Live Survey: BoreLeakagePhoto-c3fff6884a6949149d77fdcdbf837a5c.jpg
Name After Written to File: BoreLeakagePhoto-20190416-050430.jpg
The fact that a UUID is displayed at File Capture Time, but is replaced by a Date and a random number at storage time (My Survey Attachments folder) makes it impossible to create a workaround for this file management issue.
Why is the UUID displayed if it is never written?
Is there a way to replace the 6 Digit Random Number?
A basic workaround normally would be to add a custom prefix from an active survey field such as an IDENTIFIER CODE.
Currently the only way to identify one photo from another is the 6 digit random number before the file type extension. As a result the Survey Attachments folder fills with any number of non-differing names other than the random 6 digit suffix known as "?" FieldName + YYYYMMDD + ? + .ext
or my active semi workaround which is stored in the table until the image needs to be renamed.
${WORK_NO} +'_BoreLeakagePhoto' + '_' + format-date(${SurveyStartTime},'%Y%m%d') + '_' + format-date(${SurveyStartTime},'%h%M%S') + '.jpg'
Optimally names would be auto-generated from form data and custom calculations saving hours and days of downtime renaming and auditing files.
Is this fundamental issue of basic file management on the roadmap?
