I've heard that I should now be able to create a survey based of an existing feature class of polygons.
I only want to edit attributes rather than create/delete/move geometry so I thought this would be a great way to get more of our staff on board.
I created the survey using Connect, and it automatically put the geoshape field in. I tried to use this and the survey wouldn't send due to incorrect geometry type. I then read that you aren't meant to have a geometry field in for this so I took it out, but again I am still getting the same error.
Is this functionality actually supported?
IF so what am I doing wrong?!
