I have polygons representing crops/fields. Each polygon has attributes like name, crop, owner...I need to create a pesticide entry system, where field workers input what field and what pesticides were applied. I also have a list of pesticides to work with, and each pesticide has an x number of "do not enter" hours.
My end result would be a web app where we can see which fields are safe to work in and which aren't. For example, the field crew would use survey 123 to say which polygon they worked in, which pesticide was sprayed and what time the spray application happened.
I can't seem to work this one out. I tried creating related tables in arcpro, create a feature service and then create a survey from that feature service but it is not doing what I want,
thank you.
