Hi, is it possible to automaticaly give a certain property to a survey or in some way give it a higher relevansorder in the inbox. My problem is that i have houndreds of surveys in the inbox. one attribute is made by the choise OK/NOTOK. If the attribute given is NOTOK then i want to audit that again in a later time. Now it is impossible to find the right surveys in the inbox because they can be enywere. Can i somehow make survey123 mark these so they can be found easily in fieldapp. Ofcuorse they are possible to change in esri online but it is somewath not userfriendly. second question is if it is possible to change surveys in web survey123
