I need to join an external file (dbf) to a FeatureClass with ArcGIS Pro SDK. To approach this I need to run Geoprocessing Tool "Add Join", which forces the map refresh totally (including base map and all layers). If I join multiple FeatureClasses at one time, the map will refresh several times. That will cause low performance of map display.
I'm wondering if there's any solution to avoid that refresh, or any alternative approach to join external tables instead of Geoprocessing Tool to do the join. Thank you very much!.
