I have a custom application using Tab Theme template. The widget icons that show over the map in both layouts are not visible when my map displays the aerial basemap because of the transparency in those widgets.
You can see them in attached picture.
I would like to put a white background for those widgets icons or else move them up in the header controller on the right side which would be better.
Any help will be highly appreciated.
Qazi
