I would like to have my current location (geopoint) chose the loaction name from a drop down menu. I have a csv with the decimal degrees and the location name.
Name,Lat,Long
Augusta,44.3046,-69.80861165
Amherst,44.30396291,-69.80861165
I have tried using
pulldata('location','Name','Lat' >= round(${lat},4))
pulldata('location','Name','Lat' = round(${lat},4))
pulldata('location','Name','Lat', ${lat})
pulldata('location','Name','Lat', round(${lat},4))
survey
| type | name | label | hint | constraint | constraint_message | required | required_message | appearance | default | readonly | relevant | calculation | choice_filter | repeat_count | label::language1 | hint::language1 | media::audio | media::image | body::accuracyThreshold | bind::esri:fieldType | bind::esri:fieldLength | bind::esri:fieldAlias | body::esri:inputMask | bind::esri:parameters | bind::saveIncomplete | bind::type | | | | | |
| select_one location | Location | Location | | | | | | minimal | | | | | | | | | | | | | | | | | | | | | | | |
| geopoint | Map_Locaion | Map Location | | | | | | | | | | | | | | | | | | | | | | | | | | | | | |
| calculate | lat | | | | | | | | | | | pulldata("@geopoint",${Map_Locaion},"y") | | | | | | | | | | | | | | | | | | |
| calculate | lon | | | | | | | | | | | pulldata("@geopoint",${Map_Locaion},"x") | | | | | | | | | | | | | | | | | | |
| calculate | lat_Cal | | | | | | | | | | | pulldata('location','Lat','Name',${Location}) | | | | | | | | | | | | | | | | | | |
| calculate | Loc_Cal | | | | | | | | | | | pulldata('location','Name','Lat', round(${lat},4)) | | | | | | | | | | | | | | | | | | |
| note | G_E | > = to location when chosen from dropdown | | | | | | | | | | ${lat_Cal} >= round(${lat},4) | | | | | | | | | | | | | | | | | | | |
| note | LAT_CAL_NOTE | Print of Lat for drop down location | | | | | | | | | | ${lat_Cal} | | | | | | | | | | | | | | | | | | | |
| note | Lattiude | Latt | | | | | | | | | | round(${lat},4) | | | | | | | | | | | | | | | | | | | |
| note | Locat_Print | Print of Location | | | | | | | | | | ${Loc_Cal} | | | | | | | | | | | | | | | | | | | |
choices
| list_name | name | label |
| location | Augusta | Augusta |
| location | Amherst | Amherst |
