New to Survey123, and the use of GeoNet. Hopefully, someone can help or direct me to this answer, as it is likely answered elsewhere. I just can't seem to find a solution.
In short, I have been monitoring frog eggs for two seasons, now trying to clean up the data. I visit my site (a pond) and survey for frog egg masses (analogous to a bird's nest) twice a week. Each frog's egg mass I find, I record it as a new record (Egg1, Egg2, etc.), with a geopoint, and then take additional data. I return to the site every 3-4 days, looking for new egg masses (Egg7, Egg8, etc.). as well as revisit previously found egg masses (Egg1, Egg2, etc.) to record egg/tadpole development. At the end of the season, I will have about 10-15 records for each egg mass. As the points were taken in Survey 123, I will have 10+ records for say Egg1, all with a slightly different x,y coordinate. They should all be the same as they don't move. I have not found a way to have all the records show the same location (which can be from the 1st collection day). I don't need an average, just looking to have all records line up in the same spot. This would be nice for making maps (which I work around with making a filter) but also looking for a way to archive the data set to show just one coordinate.
Right now, I don't have a field that displays the x,y coordinate in my table. That data must be stored somewhere on the backend.
I have edited and moved them individually, but no way to line up correctly. I end up with a cluster of points. This is also time-consuming as I have over 100 egg masses, each with 2 to 15 records. I know there has to be a better way.
Possible solution? Is there a way to display the location, that I captured in the survey, in the attribute table? Then I could just copy/paste Egg1 location into all the records for the egg mass, which would then actually update where the records are displayed on a web map or in ArcPro?
Appreciate your help,
Ryan
