I think ArcGIS for Maps for Power BI has great potential. I work for an organisation that produces many dashboards and this added capability is a welcome addition. I've just started looking at it today so have a couple of questions:
1. I've added some locations to my map directly from a SQL Server database. For selections I can use either the select individual locations tool or the select multiple locations tool but I cannot use the 'Select locations using an area' tool. Reading the help it looks like this tool would only be enabled if I'd added a reference layer. I just don't get that? If you are allowing a me to select multiple locations based on an area (polygon), I don't get why I could not select them based on a polygon that i digitised myself. Assuming I'm not doing something wrong, are there any plans to support this in the future?
2. I've selected some points. What I would like to be able to do is to display my selection results in a power BI table control. Is that possible? If not, is that on the road map please?
Mike
