I am not able to use Survey123 to collect related records (inspections) when the Utility Network Layers is part of the FeatureService.
When I configure the Survey against a FeatureService without the Utility Network Layer the Survey works OK.
The new Collector for ArcGIS on iOS and the SmartEdit widget in WAB work also.
In attached screenshot you can see the Survey "hangs" on the "Water Utility Network" layer.
The other screenshot shows the form_id and submission_url. The submission_url references a featureservice referencing the UNM layer.
Any suggestions on how to solve this?
Regards, Maarten Tromp
