Have found that when using python API with IWA enabled Portal, the python API works fine with Portal operations, but fails on Server requests due to an issue with generate_token(). a POST request is being sent with &token=None, which is rejected.
REQUEST: https://myportalserver/portal/sharing/rest/generateToken, {'serverURL': 'https://myfederatedarcgiserver/arcgis/admin', 'token': None, 'expiration': '1440', 'f': 'json', 'request': 'getToken', 'referer': 'http'}
RESPONSE: https://myportalserver/portal/sharing/rest/generateToken, {"error":{"code":400,"message":"Unable to generate token.","details":["Unable to generate token for this server"]}}
eg
gis = GIS("https://myportalserver/portal")
print("Logged in as: " + gis.properties.user.username)
#this fails
gis_servers = gis.admin.servers.list()
python api 1.5.0
Python 3.6.4 with arcgis pip installed from pypi.org
Portal 10.5.1
ArcGIS server 10.5.1 federated with portal
IIS web adapter /portal (Windows authentication enabled, anonymous disabled)
IIS web adapter /arcgis (Anonymous enabled)
thanks,
Damian
