Hi there, I'm new to coding for survey 123 and I was wondering if someone could help me out.
I'm basically trying to create a check on a goshawk survey form to prevent conflicting data being entered. I want this check to be based on the response choice from two separate "select one" labels. Here is the example:
If the "yes" choice is selected for the "UTMs Accurate?" label, and the "unknown" choice is selected for the "Is nest Active?" label I want to be able generate a sub label with the question "Did you find the nest?" with a "yes" or "no" choice.
Is it possible for a response prompt like this to be activated only when two choices from two separate labels are selected? Or am I better off just generating that response when only one of the choices is selected?
Thanks for the help!
