Hi,I am developing an extension similar to American community Survey Mapping, I am trying to populate Combo box with TOC layers, or by using open command in my form, but I am getting nullreferenceexception was unhandled by user code error near: Dim num2 As Integer = (strArray.Length - 1)
Also I am getting many warning messages like "Variable 'variableName' is passed by reference before it has been assigned a value. A null reference exception could result at runtime". Here is part of the code where I get the error.Private Sub CmdOpenFeture_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles CmdOpenFeture.Click Dim obj2 As IEnumGxObject Dim dialog As IGxDialog = New GxDialogClass Dim filters As IGxObjectFilterCollection = DirectCast(dialog, IGxObjectFilterCollection) Dim filter5 As IGxObjectFilter = New GxFilterTablesAndFeatureClassesClass Dim filter As IGxObjectFilter = New GxFilterPersonalGeodatabasesClass Dim filter2 As IGxObjectFilter = New GxFilterPGDBFeatureClassesClass Dim filter3 As IGxObjectFilter = New GxFilterPGDBFeatureDatasetsClass Dim filter4 As IGxObjectFilter = New GxFilterPGDBTablesClass filters.AddFilter(filter5, True) filters.AddFilter(filter, False) filters.AddFilter(filter3, False) filters.AddFilter(filter4, False) Dim dialog2 As IGxDialog = dialog dialog2.AllowMultiSelect = False dialog2.ButtonCaption = "Select" dialog2.Title = "Select Input File" Dim flag As Boolean = dialog2.DoModalOpen(0, obj2) dialog2 = Nothing If flag Then Dim strArray As String() Dim fullName As String = obj2.Next.FullName CboOpenfeature.Text = fullName InputDataCmd.readFieldFromFeature(fullName, (strArray)) CboFeaturefield.Items.Clear() Dim num2 As Integer = (strArray.Length - 1) Dim i As Integer = 0 Do While (i <= num2) CboFeaturefield.Items.Add(strArray(i)) i += 1 Loop TxtOutputPath.Text = (InputDataCmd.featureWorkspacePath & "\" & InputDataCmd.featureName & "_joined.shp") End If End Sub
I do appreciate your helpThank you
