From SDE 10.6.1 on SQL 2014 ENT, I have some ghost replicas left over from a years ago TS case. The feature services that spawned them are long gone. How to remove them?
<SPAN class="keyword token">SELECT</SPAN>
ITEMS<SPAN class="punctuation token">.</SPAN>Definition <SPAN class="punctuation token">.</SPAN><SPAN class="keyword token">value</SPAN><SPAN class="punctuation token">(</SPAN> <SPAN class="string token">'(/GPSyncReplica/ID)[1]'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'nvarchar(max)'</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">AS</SPAN> <SPAN class="string token">"ID"</SPAN> <SPAN class="punctuation token">,</SPAN>
ITEMS<SPAN class="punctuation token">.</SPAN>Definition <SPAN class="punctuation token">.</SPAN><SPAN class="keyword token">value</SPAN><SPAN class="punctuation token">(</SPAN> <SPAN class="string token">'(/GPSyncReplica/ReplicaName)[1]'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'nvarchar(max)'</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">AS</SPAN> <SPAN class="string token">"Replica Name"</SPAN> <SPAN class="punctuation token">,</SPAN>
ITEMS<SPAN class="punctuation token">.</SPAN>Definition <SPAN class="punctuation token">.</SPAN><SPAN class="keyword token">value</SPAN><SPAN class="punctuation token">(</SPAN> <SPAN class="string token">'(/GPSyncReplica/ReplicaID)[1]'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'nvarchar(max)'</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">AS</SPAN> <SPAN class="string token">"Replica ID"</SPAN> <SPAN class="punctuation token">,</SPAN>
ITEMS<SPAN class="punctuation token">.</SPAN>Definition <SPAN class="punctuation token">.</SPAN><SPAN class="keyword token">value</SPAN><SPAN class="punctuation token">(</SPAN> <SPAN class="string token">'(/GPSyncReplica/CreationDate)[1]'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'nvarchar(max)'</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">AS</SPAN> <SPAN class="string token">"Creation Date"</SPAN><SPAN class="punctuation token">,</SPAN>
ITEMS<SPAN class="punctuation token">.</SPAN>Definition <SPAN class="punctuation token">.</SPAN><SPAN class="keyword token">value</SPAN><SPAN class="punctuation token">(</SPAN> <SPAN class="string token">'(/GPSyncReplica/GPSyncDatasets/GPSyncDataset/DatasetName)[1]'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'nvarchar(max)'</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">AS</SPAN> <SPAN class="string token">"Dataset Name"</SPAN>
<SPAN class="keyword token">from</SPAN>
dbo<SPAN class="punctuation token">.</SPAN>GDB_ITEMS <SPAN class="keyword token">AS</SPAN> ITEMS <SPAN class="keyword token">INNER</SPAN> <SPAN class="keyword token">JOIN</SPAN> dbo<SPAN class="punctuation token">.</SPAN>GDB_ITEMTYPES <SPAN class="keyword token">AS</SPAN> ITEMTYPES
<SPAN class="keyword token">ON</SPAN> ITEMS <SPAN class="punctuation token">.</SPAN><SPAN class="keyword token">Type</SPAN> <SPAN class="operator token">=</SPAN> ITEMTYPES <SPAN class="punctuation token">.</SPAN>UUID
<SPAN class="keyword token">WHERE</SPAN>
ITEMTYPES<SPAN class="punctuation token">.</SPAN> Name <SPAN class="operator token">=</SPAN> <SPAN class="string token">'Sync Replica'</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
ID Replica Name Replica ID Creation Date Dataset Name
<SPAN class="operator token">-</SPAN><SPAN class="number token">1</SPAN> DBO<SPAN class="punctuation token">.</SPAN>Ags_Fs A2302934<SPAN class="operator token">-</SPAN>20B6<SPAN class="operator token">-</SPAN>41D4<SPAN class="operator token">-</SPAN>B48F<SPAN class="operator token">-</SPAN>1AD84A1165E2 <SPAN class="number token">2014</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">12</SPAN><SPAN class="operator token">-</SPAN>17T18:<SPAN class="number token">32</SPAN>:<SPAN class="number token">16.27</SPAN> PFMD<SPAN class="punctuation token">.</SPAN>DBO<SPAN class="punctuation token">.</SPAN>ESRI_TEST_MSFT
<SPAN class="operator token">-</SPAN><SPAN class="number token">1</SPAN> DBO<SPAN class="punctuation token">.</SPAN>Ags_Fs_1418841420633 5ECE3404<SPAN class="operator token">-</SPAN>607B<SPAN class="operator token">-</SPAN>4F04<SPAN class="operator token">-</SPAN>A1E4<SPAN class="operator token">-</SPAN>C32FDD2EAA43 <SPAN class="number token">2014</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">12</SPAN><SPAN class="operator token">-</SPAN>17T18:<SPAN class="number token">36</SPAN>:<SPAN class="number token">01.147</SPAN> PFMD<SPAN class="punctuation token">.</SPAN>DBO<SPAN class="punctuation token">.</SPAN>ESRI_TEST_MSFT
<SPAN class="operator token">-</SPAN><SPAN class="number token">1</SPAN> DBO<SPAN class="punctuation token">.</SPAN>Ags_Fs_1418841988647 22D0DEA1<SPAN class="operator token">-</SPAN>C164<SPAN class="operator token">-</SPAN>4ADF<SPAN class="operator token">-</SPAN>81C4<SPAN class="operator token">-</SPAN>B1C332D607A5 <SPAN class="number token">2014</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">12</SPAN><SPAN class="operator token">-</SPAN>17T18:<SPAN class="number token">46</SPAN>:<SPAN class="number token">11.3</SPAN> PFMD<SPAN class="punctuation token">.</SPAN>DBO<SPAN class="punctuation token">.</SPAN>ESRI_TEST_MSFT
<SPAN class="number token">35719</SPAN> DBO<SPAN class="punctuation token">.</SPAN>Ags_Fs_1418909174993 9FA30948<SPAN class="operator token">-</SPAN>67D3<SPAN class="operator token">-</SPAN>4ACB<SPAN class="number token">-8396</SPAN><SPAN class="operator token">-</SPAN>EA720ABF7544 <SPAN class="number token">2014</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">12</SPAN><SPAN class="operator token">-</SPAN>18T13:<SPAN class="number token">26</SPAN>:<SPAN class="number token">01.787</SPAN> PFMD<SPAN class="punctuation token">.</SPAN>DBO<SPAN class="punctuation token">.</SPAN>ESRI_TEST_MSFT
<SPAN class="operator token">-</SPAN><SPAN class="number token">1</SPAN> DBO<SPAN class="punctuation token">.</SPAN>Ags_Fs_1419181999753 84E3E701<SPAN class="operator token">-</SPAN>38EF<SPAN class="operator token">-</SPAN>486E<SPAN class="operator token">-</SPAN>9BAB<SPAN class="operator token">-</SPAN>32D5BBDC87FC <SPAN class="number token">2014</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">12</SPAN><SPAN class="operator token">-</SPAN>21T17:<SPAN class="number token">11</SPAN>:<SPAN class="number token">11.93</SPAN> PFMD<SPAN class="punctuation token">.</SPAN>DBO<SPAN class="punctuation token">.</SPAN>TRAILSIGN
<SPAN class="operator token">-</SPAN><SPAN class="number token">1</SPAN> DBO<SPAN class="punctuation token">.</SPAN>Ags_Fs_1418841209303 C3038FE1<SPAN class="operator token">-</SPAN>384E<SPAN class="operator token">-</SPAN>4A2F<SPAN class="operator token">-</SPAN>81B8<SPAN class="operator token">-</SPAN>3752D693D41F <SPAN class="number token">2014</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">12</SPAN><SPAN class="operator token">-</SPAN>17T18:<SPAN class="number token">33</SPAN>:<SPAN class="number token">03.64</SPAN> PFMD<SPAN class="punctuation token">.</SPAN>DBO<SPAN class="punctuation token">.</SPAN>ESRI_TEST_MSFT
<SPAN class="operator token">-</SPAN><SPAN class="number token">1</SPAN> DBO<SPAN class="punctuation token">.</SPAN>Ags_Fs_1419186441983 15B5D13D<SPAN class="operator token">-</SPAN>70A4<SPAN class="number token">-4099</SPAN><SPAN class="operator token">-</SPAN>84DE<SPAN class="operator token">-</SPAN>3001B4639EEF <SPAN class="number token">2014</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">12</SPAN><SPAN class="operator token">-</SPAN>21T18:<SPAN class="number token">25</SPAN>:<SPAN class="number token">30.603</SPAN> PFMD<SPAN class="punctuation token">.</SPAN>DBO<SPAN class="punctuation token">.</SPAN>TRAILSIGN
<SPAN class="operator token">-</SPAN><SPAN class="number token">1</SPAN> DBO<SPAN class="punctuation token">.</SPAN>Ags_Fs_1419262786420 96CBBD68<SPAN class="operator token">-</SPAN>49E3<SPAN class="number token">-4162</SPAN><SPAN class="operator token">-</SPAN>946E<SPAN class="operator token">-</SPAN>2EEB7FC35154 <SPAN class="number token">2014</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">12</SPAN><SPAN class="operator token">-</SPAN>22T15:<SPAN class="number token">39</SPAN>:<SPAN class="number token">24.667</SPAN> PFMD<SPAN class="punctuation token">.</SPAN>DBO<SPAN class="punctuation token">.</SPAN>ESRI_TEST_MSFT
<SPAN class="number token">40523</SPAN> DBO<SPAN class="punctuation token">.</SPAN>Ags_Fs_1420049785970 1EE77463<SPAN class="operator token">-</SPAN>ED4F<SPAN class="operator token">-</SPAN>431D<SPAN class="number token">-9395</SPAN><SPAN class="operator token">-</SPAN>663C85AC8EAC <SPAN class="number token">2014</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">12</SPAN><SPAN class="operator token">-</SPAN>31T18:<SPAN class="number token">16</SPAN>:<SPAN class="number token">07.217</SPAN> PFMD<SPAN class="punctuation token">.</SPAN>DBO<SPAN class="punctuation token">.</SPAN>ESRI_TEST_MSFT
<SPAN class="number token">97711</SPAN> DBO<SPAN class="punctuation token">.</SPAN>Ags_Fs_1522248749793 8BA06387<SPAN class="operator token">-</SPAN>0C91<SPAN class="operator token">-</SPAN>4D02<SPAN class="operator token">-</SPAN>8BF3<SPAN class="operator token">-</SPAN>A024293E297E <SPAN class="number token">2018</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">03</SPAN><SPAN class="operator token">-</SPAN>28T14:<SPAN class="number token">52</SPAN>:<SPAN class="number token">20.023</SPAN> PFMD<SPAN class="punctuation token">.</SPAN>DBO<SPAN class="punctuation token">.</SPAN>TEST_EMPTY<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
