Does ESRI provide any "inbound data" mechanism, specifically a service API for data import, that allows data to be added/imported from some other source into it's own geodatabase?
Everything I've seen like Feature Services or Map services are external facing "advertised services" that are to be consumed by other applications to transfer data "outbound" to other sources.
Or, is there a way to map field-by-field an auxiliary database of a different database vendor type (like Oracle) directly to the ESRI geodatabase or a different type (like PostgreSql) and have it constantly synchronized in real-time or is cumbersome script-based ETL the only mechanism (like DBConvert/DBSync or other similar script based solution)?
I'm just learning the ESRI product-line so thanks in advance and I apologize if this is a stupid question.
