I am trying to apply symbology to a group of raster layers, and one feature layer with an add-in. Everything appears to work fine with all layers loaded into the map and showing the correct symbology, however, when I click on any raster symbology in the contents pane, an Update Colorizer Failed! warning shows up in the symbology pane, and the symbology reverts back to default. My current workaround is the save the map, close the project, and reopen before I click on anything in the contents. This seems to correct the update colorizer issue.
Is there anything I can do so I don't have to close/reopen to get this to work? Code shown below:
<SPAN class="keyword token">public</SPAN> <SPAN class="keyword token">async</SPAN> <SPAN class="keyword token">void</SPAN> <SPAN class="token function">loadLayers</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">string</SPAN> path<SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">string</SPAN> plan<SPAN class="punctuation token">)</SPAN>
<SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">string</SPAN> projectPath <SPAN class="operator token">=</SPAN> path<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">string</SPAN> modelPath <SPAN class="operator token">=</SPAN> System<SPAN class="punctuation token">.</SPAN>IO<SPAN class="punctuation token">.</SPAN>Path<SPAN class="punctuation token">.</SPAN><SPAN class="token function">GetDirectoryName</SPAN><SPAN class="punctuation token">(</SPAN>projectPath<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">string</SPAN> planName <SPAN class="operator token">=</SPAN> plan<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">string</SPAN> depthPath <SPAN class="operator token">=</SPAN> System<SPAN class="punctuation token">.</SPAN>IO<SPAN class="punctuation token">.</SPAN>Path<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Combine</SPAN><SPAN class="punctuation token">(</SPAN>modelPath<SPAN class="punctuation token">,</SPAN> plan<SPAN class="punctuation token">,</SPAN><SPAN class="string token">"Depth (Max).hydroDEM.tif"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">string</SPAN> durationPath <SPAN class="operator token">=</SPAN> System<SPAN class="punctuation token">.</SPAN>IO<SPAN class="punctuation token">.</SPAN>Path<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Combine</SPAN><SPAN class="punctuation token">(</SPAN>modelPath<SPAN class="punctuation token">,</SPAN> plan<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Duration (0.5ft hrs).hydroDEM.tif"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">string</SPAN> elevationPath <SPAN class="operator token">=</SPAN> System<SPAN class="punctuation token">.</SPAN>IO<SPAN class="punctuation token">.</SPAN>Path<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Combine</SPAN><SPAN class="punctuation token">(</SPAN>modelPath<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Terrain"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Terrain.hydroDEM.tif"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">string</SPAN> velocityPath <SPAN class="operator token">=</SPAN> System<SPAN class="punctuation token">.</SPAN>IO<SPAN class="punctuation token">.</SPAN>Path<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Combine</SPAN><SPAN class="punctuation token">(</SPAN>modelPath<SPAN class="punctuation token">,</SPAN> plan<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Velocity (Max).hydroDEM.tif"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">string</SPAN> wsePath <SPAN class="operator token">=</SPAN> System<SPAN class="punctuation token">.</SPAN>IO<SPAN class="punctuation token">.</SPAN>Path<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Combine</SPAN><SPAN class="punctuation token">(</SPAN>modelPath<SPAN class="punctuation token">,</SPAN> plan<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"WSE (Max).hydroDEM.tif"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">string</SPAN> meshPath <SPAN class="operator token">=</SPAN> System<SPAN class="punctuation token">.</SPAN>IO<SPAN class="punctuation token">.</SPAN>Path<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Combine</SPAN><SPAN class="punctuation token">(</SPAN>modelPath<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"2DMesh.shp"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">string</SPAN> depthLayer <SPAN class="operator token">=</SPAN> System<SPAN class="punctuation token">.</SPAN>IO<SPAN class="punctuation token">.</SPAN>Path<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Combine</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="token function">AddinAssemblyLocation</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Content"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"depth.lyrx"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">string</SPAN> durationLayer <SPAN class="operator token">=</SPAN> System<SPAN class="punctuation token">.</SPAN>IO<SPAN class="punctuation token">.</SPAN>Path<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Combine</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="token function">AddinAssemblyLocation</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Content"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"duration.lyrx"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">string</SPAN> elevationLayer <SPAN class="operator token">=</SPAN> System<SPAN class="punctuation token">.</SPAN>IO<SPAN class="punctuation token">.</SPAN>Path<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Combine</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="token function">AddinAssemblyLocation</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Content"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"elevation.lyrx"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">string</SPAN> velocityLayer <SPAN class="operator token">=</SPAN> System<SPAN class="punctuation token">.</SPAN>IO<SPAN class="punctuation token">.</SPAN>Path<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Combine</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="token function">AddinAssemblyLocation</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Content"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"velocity.lyrx"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">string</SPAN> wseLayer <SPAN class="operator token">=</SPAN> System<SPAN class="punctuation token">.</SPAN>IO<SPAN class="punctuation token">.</SPAN>Path<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Combine</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="token function">AddinAssemblyLocation</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Content"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"WSE.lyrx"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">string</SPAN> meshLayer <SPAN class="operator token">=</SPAN> System<SPAN class="punctuation token">.</SPAN>IO<SPAN class="punctuation token">.</SPAN>Path<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Combine</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="token function">AddinAssemblyLocation</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Content"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"mesh.lyrx"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
RasterLayer velocityMap <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">;</SPAN>
RasterLayer depthMap <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">;</SPAN>
RasterLayer durationMap <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">;</SPAN>
RasterLayer elevationMap <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">;</SPAN>
RasterLayer wseMap <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">;</SPAN>
FeatureLayer meshMap <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">;</SPAN>
CancelableProgressorSource ps <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">CancelableProgressorSource</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Starting Process..."</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Cancel"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN><SPAN class="punctuation token">(</SPAN>MapView<SPAN class="punctuation token">.</SPAN>Active <SPAN class="operator token">!=</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">if</SPAN><SPAN class="punctuation token">(</SPAN>System<SPAN class="punctuation token">.</SPAN>IO<SPAN class="punctuation token">.</SPAN>File<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Exists</SPAN><SPAN class="punctuation token">(</SPAN>elevationPath<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
ps<SPAN class="punctuation token">.</SPAN>Progressor<SPAN class="punctuation token">.</SPAN>Message <SPAN class="operator token">=</SPAN> <SPAN class="string token">"Loading terrain grid"</SPAN><SPAN class="punctuation token">;</SPAN>
elevationMap <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">await</SPAN> QueuedTask<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Run</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">=</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="keyword token">return</SPAN> <SPAN class="punctuation token">(</SPAN>RasterLayer<SPAN class="punctuation token">)</SPAN>LayerFactory<SPAN class="punctuation token">.</SPAN>Instance<SPAN class="punctuation token">.</SPAN><SPAN class="token function">CreateLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Uri</SPAN><SPAN class="punctuation token">(</SPAN>elevationPath<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> MapView<SPAN class="punctuation token">.</SPAN>Active<SPAN class="punctuation token">.</SPAN>Map<SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Terrain"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>System<SPAN class="punctuation token">.</SPAN>IO<SPAN class="punctuation token">.</SPAN>File<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Exists</SPAN><SPAN class="punctuation token">(</SPAN>wsePath<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
ps<SPAN class="punctuation token">.</SPAN>Progressor<SPAN class="punctuation token">.</SPAN>Message <SPAN class="operator token">=</SPAN> <SPAN class="string token">"Loading WSE grid"</SPAN><SPAN class="punctuation token">;</SPAN>
wseMap <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">await</SPAN> QueuedTask<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Run</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">=</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="keyword token">return</SPAN> <SPAN class="punctuation token">(</SPAN>RasterLayer<SPAN class="punctuation token">)</SPAN>LayerFactory<SPAN class="punctuation token">.</SPAN>Instance<SPAN class="punctuation token">.</SPAN><SPAN class="token function">CreateLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Uri</SPAN><SPAN class="punctuation token">(</SPAN>wsePath<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> MapView<SPAN class="punctuation token">.</SPAN>Active<SPAN class="punctuation token">.</SPAN>Map<SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Maximum WSE"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>System<SPAN class="punctuation token">.</SPAN>IO<SPAN class="punctuation token">.</SPAN>File<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Exists</SPAN><SPAN class="punctuation token">(</SPAN>depthPath<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
ps<SPAN class="punctuation token">.</SPAN>Progressor<SPAN class="punctuation token">.</SPAN>Message <SPAN class="operator token">=</SPAN> <SPAN class="string token">"Loading depth grid"</SPAN><SPAN class="punctuation token">;</SPAN>
depthMap <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">await</SPAN> QueuedTask<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Run</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">=</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="keyword token">return</SPAN> <SPAN class="punctuation token">(</SPAN>RasterLayer<SPAN class="punctuation token">)</SPAN>LayerFactory<SPAN class="punctuation token">.</SPAN>Instance<SPAN class="punctuation token">.</SPAN><SPAN class="token function">CreateLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Uri</SPAN><SPAN class="punctuation token">(</SPAN>depthPath<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> MapView<SPAN class="punctuation token">.</SPAN>Active<SPAN class="punctuation token">.</SPAN>Map<SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Maximum Depth"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>System<SPAN class="punctuation token">.</SPAN>IO<SPAN class="punctuation token">.</SPAN>File<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Exists</SPAN><SPAN class="punctuation token">(</SPAN>durationPath<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
ps<SPAN class="punctuation token">.</SPAN>Progressor<SPAN class="punctuation token">.</SPAN>Message <SPAN class="operator token">=</SPAN> <SPAN class="string token">"Loading duration grid"</SPAN><SPAN class="punctuation token">;</SPAN>
durationMap <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">await</SPAN> QueuedTask<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Run</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">=</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="keyword token">return</SPAN> <SPAN class="punctuation token">(</SPAN>RasterLayer<SPAN class="punctuation token">)</SPAN>LayerFactory<SPAN class="punctuation token">.</SPAN>Instance<SPAN class="punctuation token">.</SPAN><SPAN class="token function">CreateLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Uri</SPAN><SPAN class="punctuation token">(</SPAN>durationPath<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> MapView<SPAN class="punctuation token">.</SPAN>Active<SPAN class="punctuation token">.</SPAN>Map<SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Duration over 0.5ft depth"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>System<SPAN class="punctuation token">.</SPAN>IO<SPAN class="punctuation token">.</SPAN>File<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Exists</SPAN><SPAN class="punctuation token">(</SPAN>velocityPath<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
ps<SPAN class="punctuation token">.</SPAN>Progressor<SPAN class="punctuation token">.</SPAN>Message <SPAN class="operator token">=</SPAN> <SPAN class="string token">"Loading velocity grid"</SPAN><SPAN class="punctuation token">;</SPAN>
velocityMap <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">await</SPAN> QueuedTask<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Run</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">=</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="keyword token">return</SPAN> <SPAN class="punctuation token">(</SPAN>RasterLayer<SPAN class="punctuation token">)</SPAN>LayerFactory<SPAN class="punctuation token">.</SPAN>Instance<SPAN class="punctuation token">.</SPAN><SPAN class="token function">CreateLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Uri</SPAN><SPAN class="punctuation token">(</SPAN>velocityPath<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> MapView<SPAN class="punctuation token">.</SPAN>Active<SPAN class="punctuation token">.</SPAN>Map<SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Maximum Velocity"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>System<SPAN class="punctuation token">.</SPAN>IO<SPAN class="punctuation token">.</SPAN>File<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Exists</SPAN><SPAN class="punctuation token">(</SPAN>meshPath<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
ps<SPAN class="punctuation token">.</SPAN>Progressor<SPAN class="punctuation token">.</SPAN>Message <SPAN class="operator token">=</SPAN> <SPAN class="string token">"Loading 2D mesh polygon"</SPAN><SPAN class="punctuation token">;</SPAN>
meshMap <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">await</SPAN> QueuedTask<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Run</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">=</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="keyword token">return</SPAN> <SPAN class="punctuation token">(</SPAN>FeatureLayer<SPAN class="punctuation token">)</SPAN>LayerFactory<SPAN class="punctuation token">.</SPAN>Instance<SPAN class="punctuation token">.</SPAN><SPAN class="token function">CreateLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Uri</SPAN><SPAN class="punctuation token">(</SPAN>meshPath<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> MapView<SPAN class="punctuation token">.</SPAN>Active<SPAN class="punctuation token">.</SPAN>Map<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
ps<SPAN class="punctuation token">.</SPAN>Progressor<SPAN class="punctuation token">.</SPAN>Message <SPAN class="operator token">=</SPAN> <SPAN class="string token">"Applying symbology..."</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>MapView<SPAN class="punctuation token">.</SPAN>Active <SPAN class="operator token">!=</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>elevationMap <SPAN class="operator token">!=</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">var</SPAN> elevationDoc <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">LayerDocument</SPAN><SPAN class="punctuation token">(</SPAN>elevationLayer<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> elevationParams <SPAN class="operator token">=</SPAN> elevationDoc<SPAN class="punctuation token">.</SPAN><SPAN class="token function">GetCIMLayerDocument</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> elevationColorizer <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">(</SPAN>CIMRasterLayer<SPAN class="punctuation token">)</SPAN>elevationParams<SPAN class="punctuation token">.</SPAN>LayerDefinitions<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>Colorizer <SPAN class="keyword token">as</SPAN> CIMRasterStretchColorizer<SPAN class="punctuation token">;</SPAN>
elevationMap<SPAN class="punctuation token">.</SPAN><SPAN class="token function">SetColorizer</SPAN><SPAN class="punctuation token">(</SPAN>elevationColorizer<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>wseMap <SPAN class="operator token">!=</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">var</SPAN> wseDoc <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">LayerDocument</SPAN><SPAN class="punctuation token">(</SPAN>wseLayer<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> wseParams <SPAN class="operator token">=</SPAN> wseDoc<SPAN class="punctuation token">.</SPAN><SPAN class="token function">GetCIMLayerDocument</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> wseColorizer <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">(</SPAN>CIMRasterLayer<SPAN class="punctuation token">)</SPAN>wseParams<SPAN class="punctuation token">.</SPAN>LayerDefinitions<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>Colorizer <SPAN class="keyword token">as</SPAN> CIMRasterDiscreteColorColorizer<SPAN class="punctuation token">;</SPAN>
wseMap<SPAN class="punctuation token">.</SPAN><SPAN class="token function">SetColorizer</SPAN><SPAN class="punctuation token">(</SPAN>wseColorizer<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>depthMap <SPAN class="operator token">!=</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">var</SPAN> depthDoc <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">LayerDocument</SPAN><SPAN class="punctuation token">(</SPAN>depthLayer<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> depthParams <SPAN class="operator token">=</SPAN> depthDoc<SPAN class="punctuation token">.</SPAN><SPAN class="token function">GetCIMLayerDocument</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> depthColorizer <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">(</SPAN>CIMRasterLayer<SPAN class="punctuation token">)</SPAN>depthParams<SPAN class="punctuation token">.</SPAN>LayerDefinitions<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>Colorizer <SPAN class="keyword token">as</SPAN> CIMRasterClassifyColorizer<SPAN class="punctuation token">;</SPAN>
depthMap<SPAN class="punctuation token">.</SPAN><SPAN class="token function">SetColorizer</SPAN><SPAN class="punctuation token">(</SPAN>depthColorizer<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>durationMap <SPAN class="operator token">!=</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">var</SPAN> durationDoc <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">LayerDocument</SPAN><SPAN class="punctuation token">(</SPAN>durationLayer<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> durationParams <SPAN class="operator token">=</SPAN> durationDoc<SPAN class="punctuation token">.</SPAN><SPAN class="token function">GetCIMLayerDocument</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> durationColorizer <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">(</SPAN>CIMRasterLayer<SPAN class="punctuation token">)</SPAN>durationParams<SPAN class="punctuation token">.</SPAN>LayerDefinitions<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>Colorizer <SPAN class="keyword token">as</SPAN> CIMRasterClassifyColorizer<SPAN class="punctuation token">;</SPAN>
durationMap<SPAN class="punctuation token">.</SPAN><SPAN class="token function">SetColorizer</SPAN><SPAN class="punctuation token">(</SPAN>durationColorizer<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>velocityMap <SPAN class="operator token">!=</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">var</SPAN> velocityDoc <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">LayerDocument</SPAN><SPAN class="punctuation token">(</SPAN>velocityLayer<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> velocityParams <SPAN class="operator token">=</SPAN> velocityDoc<SPAN class="punctuation token">.</SPAN><SPAN class="token function">GetCIMLayerDocument</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> velocityColorizer <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">(</SPAN>CIMRasterLayer<SPAN class="punctuation token">)</SPAN>velocityParams<SPAN class="punctuation token">.</SPAN>LayerDefinitions<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>Colorizer <SPAN class="keyword token">as</SPAN> CIMRasterClassifyColorizer<SPAN class="punctuation token">;</SPAN>
velocityMap<SPAN class="punctuation token">.</SPAN><SPAN class="token function">SetColorizer</SPAN><SPAN class="punctuation token">(</SPAN>velocityColorizer<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>meshMap <SPAN class="operator token">!=</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">)</SPAN>
LayerDocument meshDocument <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">LayerDocument</SPAN><SPAN class="punctuation token">(</SPAN>meshLayer<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> meshParameters <SPAN class="operator token">=</SPAN> meshDocument<SPAN class="punctuation token">.</SPAN><SPAN class="token function">GetCIMLayerDocument</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> layerRenderer <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">(</SPAN>CIMFeatureLayer<SPAN class="punctuation token">)</SPAN>meshParameters<SPAN class="punctuation token">.</SPAN>LayerDefinitions<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>Renderer <SPAN class="keyword token">as</SPAN> CIMRenderer<SPAN class="punctuation token">;</SPAN>
meshMap<SPAN class="punctuation token">.</SPAN><SPAN class="token function">SetRenderer</SPAN><SPAN class="punctuation token">(</SPAN>layerRenderer<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> ps<SPAN class="punctuation token">.</SPAN>Progressor<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
