I saw an earlier post from 2015 about this same request, but wanted to re-kindle the issue because, although the widget only hides 1/2 the screen in mobile, it still hides the selected point when zoomed in to the result (see screenshot).
I thought of two ways to address the issue. In a previous app, for the 'near me' widget, I just put the following code in the _createBuffer() function:
<SPAN class="keyword token">var</SPAN> extent<SPAN class="punctuation token">;</SPAN>
geometryService<SPAN class="punctuation token">.</SPAN><SPAN class="token function">buffer</SPAN><SPAN class="punctuation token">(</SPAN>params<SPAN class="punctuation token">,</SPAN> lang<SPAN class="punctuation token">.</SPAN><SPAN class="token function">hitch</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>
geometries<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>window<SPAN class="punctuation token">.</SPAN>appInfo<SPAN class="punctuation token">.</SPAN>isRunInMobile<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"geometries "</SPAN><SPAN class="punctuation token">,</SPAN> geometries<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">getExtent</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
extent <SPAN class="operator token">=</SPAN> geometries<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">getExtent</SPAN><SPAN class="punctuation
