I want to connect a remote sever via python code ,my code is :
arcpy.env.workspace = r"Database Connections\Connection to 10.246.146.120.sde"
wk = r"Database Connections\Connection to 10.246.146.120.sde"
def list_feature_batch1(pathsde):
env.workspace = pathsde
# print arcpy.env.workspace
datasets = arcpy.ListDatasets()
datasets = [''] + datasets if datasets is not None else []
#print datasets
wklst = []
for ds in datasets:
# print ds
# env.workspace = env.workspace + os.sep + ds
wk = env.workspace + os.sep + ds
# print env.workspace
wklst.append(wk)
return wklst
# database = 'Database Connections\\Connection to 10.246.146.120.sde'
# versions = arcpy.ListVersions(database)
for dataset
in list_feature_batch1(wk):
print dataset
list_feature_batch1 is a function,it works well.
why doesnot the code work,but when I add code that
arcpy.env.workspace = r"Database Connections\Connection to 127.0.0.1.sde
the code can run correctly.
