I have a survey that was created in Survey123 Connect. I have added some extra choice field and when I try to publish the survey publishing hangs. I've noticed that there is no form or feature layer in the survey folder when I view it through AGOL - Content. (I am not sure how these would have been deleted?)
When I view the survey through Survey123 Web there is data (386 records) but the pencil symbol that directs you to open in Connect or the Collaborate symbol is not available.
My question - Is the issue with publishing because the form and feature not present?
If so how do I replace them with the data that is available in Survey123 Web?
We are using Survey123 Connect with Portal
Thank you
