High level - I'm trying to pass a layer from ArcGIS Pro 2.1 through an R bridge to an R script which will do some calculations and return a data set which will be plotted as a layer.
When the R script tries to execute distance_data <- arc.select(arc.open(distance_layer)) the following error is produced - Error in .select : shape fields missing.
If we separate out function calls to arc.open() and arc.select(), arc.open() executes but arc.select() throws the above error.
When we look at the attribute table of the layer, there is a column of data type 'Geography' for the layer which displays as 'Point.' If we look at the data as it is in the database table, it appears as a long Hex value. This field is also of data type 'Geography' in the database table. So, to me it looks like I do have a shape field.
