Robert
1.) How do you defined what Layers should use a popup (infotemplate) as the default and others as needed?
2.) I found 2 issue using the Foldable Theme. Formatted numeric fields and the title heading in the infowindow popup.
See attached images.
A.) Formatted Fields(Cem.jpg, Parks.jpg)
Notice that if a field contains formatted numeric values it sometime will/will not show and cannot be turned off in the config file
B.) No title (Tax Map.jpg, Subdiv.jpg)
Notice that when a URL is defined the title name is disappearing and the URL link does not always show.
I have also attached my config files to see if there is something incorrect.
