does anyone have a working example to drag a FeatureClass into a textbox on a DockPane so that the path appears in the textbox? The only drag and drop example is an Excel example that does not address a DockPane.
And in the documentation, a parameter of type DropData should be specified for the OnDrop function. Here, however, only a DropInfo object is possible ...?
public override void OnDrop(DropData dropInfo) { foreach (var item in dropInfo.Items) { if (System.IO.Path.GetExtension(item.Data as string) == ".aprx") item.Handled = true; } }
And with the DropInfo object I get neither a reference to the text box, nor to the FeatureClass.
Thank you
Alex
