Has anyone else experienced this issue on Portal For ArcGIS with Survey123 Feature Classes?
I had this error once before but I tried it again the following day and it just worked, that solution didn't work this time.
I go to the feature class Export Data>To FGDB
Enter tags, summary, and set the output location
The Export button goes gray and says "Exporting..."
Then one of two things happens:
1. I get "Error: Failed" (see attached pic)
2. The "Export" button goes back to blue, it still says exporting, and the cursor spins forever.
This particular survey was created by a user then ownership was transferred to the headless admin. I have tried exporting as both another admin user and as the headless admin user with exactly the same results.
This survey has a related table and picture attachments so an alternative format export (like csv) isn't an option.
Any suggestions or ideas on why this might be happening?
JTedrick-esristaff
