So we are running a ArcPy Export script that started failing. I am not super familiar with SQL, ArcGIS, and python but I think the intention of the script is to delete some tables and append them with new information. I have posted the script and error log is this will help. Thanks for any help in advance
Error Log:
16:05:25 Starting script
16:05:37 Opening Model
16:06:37 Processing Capacitor
16:06:37 Processing Regulator
16:06:37 Processing Transformer
16:06:37 Processing Switch
16:06:37 Processing Node
16:06:37 Processing Source
16:06:37 Processing Device
16:06:37 Processing Motor
16:06:37 Processing Generator
16:06:37 Processing Consumer
16:06:37 Processing Switchgear
16:06:37 Processing Pole
16:06:37 Processing Tower
16:06:37 Processing Pad
16:06:37 Processing Pedestal
16:06:37 Processing JunctionBox
16:06:37 Processing Enclosure
16:06:37 Processing Vault
16:06:37 Processing PullBox
16:06:37 Processing ForeignStructure
16:06:37 Processing Marker
16:06:37 Processing Light
16:06:37 Processing SurfaceStructure
16:06:37 Processing StorageLocation
16:06:37 Processing NonUtilityFacility
16:06:37 Processing Overhead
16:06:37 Processing Underground
16:06:39 Deleting records from C:\Milsoft\ArcPy Export\arcpy.sde\SDS_Milsoft_Geodatabase.DBO.Milsoft\StorageLocation
16:06:42 Appending records to C:\Milsoft\ArcPy Export\arcpy.sde\SDS_Milsoft_Geodatabase.DBO.Milsoft\StorageLocation
16:06:49 Deleting records from C:\Milsoft\ArcPy Export\arcpy.sde\SDS_Milsoft_Geodatabase.DBO.Milsoft\Transformer
16:06:54 Appending records to C:\Milsoft\ArcPy Export\arcpy.sde\SDS_Milsoft_Geodatabase.DBO.Milsoft\Transformer
16:08:00 Deleting records from C:\Milsoft\ArcPy Export\arcpy.sde\SDS_Milsoft_Geodatabase.DBO.Milsoft\JunctionBox
16:08:03 Appending records to C:\Milsoft\ArcPy Export\arcpy.sde\SDS_Milsoft_Geodatabase.DBO.Milsoft\JunctionBox
16:08:08 Deleting records from C:\Milsoft\ArcPy Export\arcpy.sde\SDS_Milsoft_Geodatabase.DBO.Milsoft\Generator
16:08:11 Appending records to C:\Milsoft\ArcPy Export\arcpy.sde\SDS_Milsoft_Geodatabase.DBO.Milsoft\Generator
16:08:15 Deleting records from C:\Milsoft\ArcPy Export\arcpy.sde\SDS_Milsoft_Geodatabase.DBO.Milsoft\Switchgear
16:08:18 Appending records to C:\Milsoft\ArcPy Export\arcpy.sde\SDS_Milsoft_Geodatabase.DBO.Milsoft\Switchgear
16:08:22 Deleting records from C:\Milsoft\ArcPy Export\arcpy.sde\SDS_Milsoft_Geodatabase.DBO.Milsoft\Source
16:08:25 Appending records to C:\Milsoft\ArcPy Export\arcpy.sde\SDS_Milsoft_Geodatabase.DBO.Milsoft\Source
16:08:30 Deleting records from C:\Milsoft\ArcPy Export\arcpy.sde\SDS_Milsoft_Geodatabase.DBO.Milsoft\Pad
16:08:36 ERROR 999999: Error executing function.
Underlying DBMS error [HY000:[Microsoft][ODBC Driver 17 for SQL Server]Unspecified error occurred on SQL Server. Connection may have been terminated by the server.] [SDS_Milsoft_Geodatabase.DBO.Pad][STATE_ID = 8256]
Failed to execute (DeleteRows).
Script:
# Import system modules
import os, gc
import arcpy
from arcpy import env
import Logging
try:
Logging.CleanPreviousFile()
Logging.LogMessage('Starting script')
env.overwriteOutput = True
#Set Model Path
env.workspace = "C:\\Milsoft\\Database\\Export Model.wm"
#Check if model is open
modelOpenFile = os.path.join(env.workspace, ".modelinuse")
if os.path.exists(modelOpenFile):
raise ValueError("Model is already open.")
#Set Output Path
#ex: "C:/output.gdb", "C:/output.sde", "C:/output", "C:/output.mdb"
outWorkspace = r"C:\Milsoft\ArcPy Export\arcpy.sde\SDS_Milsoft_Geodatabase.DBO.Milsoft"
#Get list of WMM Feature Classes
fcList = arcpy.ListFeatureClasses()
fcDict = {}
isOpen = False
# Create list of each WMM feature class path
for wmFeature in fcList:
if not isOpen:
Logging.LogMessage('Opening Model')
arcpy.GetCount_management(wmFeature)
isOpen = True
Logging.LogMessage('Processing {}'.format(wmFeature))
# Determine the new output feature class path and name
outFeatureClass = wmFeature
fcDict[wmFeature] = (outWorkspace, outFeatureClass)
for k, v in fcDict.iteritems():
#if k <> 'Transformer': continue
outFC = os.path.join(v[0], v[1])
if arcpy.Exists(outFC):
Logging.LogMessage('Deleting records from {}'.format(outFC))
arcpy.DeleteRows_management (outFC)
Logging.LogMessage('Appending records to {}'.format(outFC))
arcpy.Append_management(k, outFC, 'NO_TEST')
else:
Logging.LogMessage('Creating {}'.format(outFC))
arcpy.FeatureClassToFeatureClass_conversion(k, v[0], v[1])
gc.collect()
Logging.LogMessage('Completed export')
Logging.FlushLog()
except Exception as e:
Logging.LogErrorMessage(e.message)
Logging.FlushLog()
os.kill(os.getpid(), -9)
