Problem Context: I'm working right now on several highway plats. Part of this process in my county is designating certain parcel lines as Road Frontage so their symbology is different from a parcel boundary line. Working the highway plats necessitates making some changes to existing parcels. There are instances in which a parcel is drawn with a long boundary line or curve that, because of my highway plat, need to be split so that I can call a portion of the line Road Frontage.
Other notes:
-It is not an issue of regular intervals. The distance is different in each situation, and I often don't have a specific dimension telling me where to split the line. The original plat won't have the point at which the highway plat will intersect it, and the highway plat doesn't have the dimensions of its neighboring parcel.
-I have not been successful in using Breakpoint because I don't want a new construction and I also don't always have a specific dimension from the plat that will tell me where to split the line. It is not an issue of regular intervals either.
-I know that I can manually calculate and measure in order to insert a new line to be drawn in the traverse grid, but that doesn't work well on curves and I would like to find a simpler method.
From what I understand, if I was using the regular Editor toolbar, I could just use the Split tool to click where I want to split the line or curve. Then I could select the new segment that I want to be Road Frontage. I am searching for something equivalently simple to use in the Parcel Editor toolbar.
