Hi
I was wondering if it was possible to engage the Attribute Widget when using the default Identify Widget and in general many other searching widgets that get developed. My reasoning is that popups and widget search, etc displays that sit within the map display use up valuable map display space. Users loose that valuable map interface experience. I have started to use the Jewelry Box Theme from what's available, which would be the ideal candidate to resolving this issue, however the draw back at this stage in this theme is that you cant use multiple displays for docking and or tabbing from what I can gather. You can only set up one widget.
