So I am trying to build a widget which uses some jQuery plugins(jquery ui, jquery mobile and so on). The problem is that I can't figure out how to load this plugins. If i put the plugins in the dependencies array it doesn't work because jQuery isn't loaded first.
<SPAN class="token function">define</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'dojo/_base/declare'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'jimu/BaseWidget'</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token"><SPAN>'jimu/loaderplugins/jquery-loader!</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fcode.jquery.com%2Fjquery-git1.min.js" target="_blank">https://code.jquery.com/jquery-git1.min.js</A><SPAN>'</SPAN></SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'./lib/jquery.mobile.min'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'./lib/jquery.ui.min'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>declare<SPAN class="punctuation token">,</SPAN> BaseWidget<SPAN class="punctuation token">,</SPAN> $<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">return</SPAN> <SPAN class="token function">declare</SPAN><SPAN class="punctuation token">(</SPAN>BaseWidget<SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN>
startup<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> map <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>map<SPAN class="punctuation token">;</SPAN>
<SPAN class="token function">$</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'.jimu-widget-use-jquery .map-id'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN
