The survey has a State field followed by City field, but when the survey is re-opened from Inbox the City field is blank and I need to re-select before saving and sending.
These two fields are the only required fields and to try avoid this I added 'query' to the bind::esri:parameters column but it did not fix it.
Any help would be greatly appreciated.
