I am trying to upgrade from 10.1 geodatabase to 10.5 when I run the upgrade check it says all is good to upgrade, but when I actually run the upgrade I keep getting an error. Here is the output of the script.
Executing: UpgradeGDB "Database Connections\GISPROD as SDE.sde" PREREQUISITE_CHECK UPGRADEStart Time: Fri Sep 08 08:47:16 2017Paused the database for upgrade.There are no other active connections.User has privileges required to upgrade.Connected RDBMS instance is setup for ST_GEOMETRY configuration.Running Pre-Requisite check (C:\Users\Raymondg\AppData\Roaming\ESRI\Desktop10.5\ArcCatalog\GISPROD as SDE.sde).Instance supports XML type.Updating server tables and stored procedures.Could not update server tables and stored procedures. (branches : Error (406) DBMS error code: 406ORA-00406: COMPATIBLE parameter needs to be 12.0.0.0.0 or greaterORA-00722: Feature "SQL identity columns")Refer to upgrade logfiles for more details:C:\Users\Raymondg\AppData\Local\Esri\Desktop10.5\GDBUpgrade.logC:\Users\Raymondg\AppData\Local\Temp\sde_setup.logUnpaused the database.Failed to execute (UpgradeGDB).Failed at Fri Sep 08 08:47:17 2017 (Elapsed Time: 1.16 seconds)
Oracle Database: 12.1.0.2
OS: SLES 11 SP4
I am at a loss here. Any help appreciated.
Ray
