Summary
I found an issue where publishing a survey with a name called globalid will cause it to fail upon publishing (see 721013), despite passing all the checks in Connect. Please consider adding "globalid" or "GLOBALID" to the list of reserved words in the Advanced Excel Template.
Product Tested
Survey123 Connect for ArcGIS 2.4.60
Details
It is not possible to publish a survey with an attribute named "globalid" to an Esri-hosted #ArcGIS account. I found that attempting to publish a survey with that keyword causes an error. I suggest adding the keyword "GLOBALID" to the list of reserved words found on the types tab in the Excel Advanced Template. Then, update the Reserved Named Range in Excel to include the new list item.
The sample table below will cause the failure to occur.
| type | name | label | hint |
| text | asset_id | Asset ID | This ID comes from the Collector app |
| text | globalid | Global ID | The parent feature's global ID |
