I want to use AppStudio rady projects tamplates as base project in my application but I can not build them.For example StartPage.qml gives some errors and can not see ArcGIS.AppFramework dll's .How can I use AppStudio's ready templates as a base project.
Here is the code from StartPage.qml below:
// MapTourNew.qml
// Created 2014-09-09 08:47:16
import QtQuick 2.2
import QtQuick.Controls 1.1
import QtPositioning 5.2
import QtGraphicalEffects 1.0
import QtQuick.Layouts 1.1
import QtQuick.Dialogs 1.1
import ArcGIS.AppFramework 1.0
import ArcGIS.AppFramework.Runtime 1.0
import ArcGIS.AppFramework.Runtime.Dialogs 1.0
import ArcGIS.Runtime 10.25
App { id: app
width: 400
height: 640
Component.onCompleted: { ArcGISRuntime.loggingEnabled = false
IdentityManager.ignoreSslErrors = true;
property alias customFont : customFont
property bool isOnline: AppFramework.network.isOnline
property int scaleFactor : AppFramework.displayScaleFactor
//property int baseFontSize : Math.min(20, 20 * scaleFactor)
property int baseFontSize : app.info.propertyValue("baseFontSize", 20 * scaleFactor) property color valuehighlightColor: "#00ffffff"
property color selectColor: "yellow"
property bool isSmallScreen: false
property bool isPortait: false
property bool isSignedIn : false
//***************** Config *************************
property string galleryPageBackground : app.folder.fileUrl(app.info.propertyValue("galleryBackground","images/background3.jpg")); property string landingpageBackground : app.folder.fileUrl(app.info.propertyValue("startBackground","images/background1.jpg")); property string logoImage : app.folder.fileUrl(app.info.propertyValue("logoImage","images/esrilogo.png")); property string loginImage : app.folder.fileUrl(app.info.propertyValue("startButton","images/signin.png")); property string logoUrl : app.info.propertyValue("logoUrl","http://www.esri.com"); property bool doLogin : app.info.propertyValue("doLogin",false); property bool showDescriptionOnStartup : app.info.propertyValue("showDescriptionOnStartup",false); property bool showLogo : app.info.propertyValue("startShowLogo",true); property string customFontTTF: app.info.propertyValue("customFontTTF",""); property string portalQueryItemTypes: app.info.propertyValue("portalQueryItemTypes","type:\"Web Mapping Application\"") //portal
property var orgId : app.info.propertyValue("orgId", null); property var queryString :app.info.propertyValue("queryString", null); property var sortOrder: app.info.propertyValue("portalSortOrder","desc"); property var sortField: app.info.propertyValue("portalSortField","modified"); //colors
property color headerBackgroundColor: app.info.propertyValue("textBackgroundColor","#4c4c4c"); property string textColor : app.info.propertyValue("textColor","white"); property color titleColor: app.info.propertyValue("titleColor","black"); property color subtitleColor: app.info.propertyValue("subtitleColor","#51010a"); //maptour
property bool autoCropImage: app.info.propertyValue("autoCropImage",true); property bool showGallery: app.info.propertyValue("showGallery",true); property var webmapid: app.info.propertyValue("webmapid",""); property var tourLayerId: app.info.propertyValue("tourlayerId",""); property var mapScale: app.info.propertyValue("mapScale","70000"); property bool showBasemapSwitcher: app.info.propertyValue("showBasemapSwitcher",true); property string basemapUrl: app.info.propertyValue("basemapUrl","http://services.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer"); //custom fields
property string titleField: app.info.propertyValue("maptour_titleField","NAME"); property string descField: app.info.propertyValue("maptour_descriptionField","CAPTION"); property string thumbnailField: app.info.propertyValue("maptour_thumbnailField", "PIC_URL"); property string imageField: app.info.propertyValue("maptour_imageField","THUMB_URL"); property string iconColorField : app.info.propertyValue("maptour_iconColorField", "COLOR"); property bool customRenderer : app.info.propertyValue("maptour_customRenderer",true); property bool customSort : app.info.propertyValue("maptour_customSort",false); property string customSortField: app.info.propertyValue("maptour_customSortField","NUMBER"); property string customSortOrder: app.info.propertyValue("maptour_customSortOrder","asc"); //custom font if any
FontLoader { id: customFont
source: app.folder.fileUrl(customFontTTF)
StackView { id: stackView
anchors.fill: parent
initialItem: landingPage
function showGallery() { push(galleryPage);
function showTour(itemInfo) { stackView.push(tourPage);
stackView.currentItem.loadTour(itemInfo);
Component { id: landingPage
LandingPage { onSignInClicked: { app.isSmallScreen = (parent.width || parent.height) < 400*app.scaleFactor
app.isPortait = parent.height > parent.width
console.log("##StartPage:: DisplayScaleFactor: ", scaleFactor, " isSmallScreen: ", isSmallScreen, " isPortarit: ", isPortait); if (portalSignInDialog.portal.signedIn || !app.doLogin) { if(!app.showGallery) { stackView.showTour(null);
} else { stackView.showGallery();
} else { portalSignInDialog.visible = true;
Component { id: galleryPage
GalleryPage { portal: portalSignInDialog.portal
onExitClicked: { portal.signOut();
stackView.pop();
onTourSelected: {
tourItemData.downloadTour(itemInfo);
Component { id: tourPage
TourPage {
onExit: { stackView.pop();
PortalSignInDialog {
settingsGroup: "portal"
portal: Portal {
onSignInComplete: {
isSignedIn = true;
onSignInError: {
isSignedIn = false
console.log("***** siginin error event *****"); }
onRejected: { console.log("****** signin on closed event *****"); stackView.showGallery()
PortalDownloadItemData {
property PortalItemInfo itemInfo
portal
function downloadTour(itemInfo) { console.log("Itemid: ", itemInfo.itemId); toursFolder.makePath(itemInfo.itemId);
//tourItemData.responseFilename = AppFramework.resolvedPathUrl(toursFolder.filePath(itemInfo.itemId + "/mapTourInfo.json"));
//console.log("*** Sathya filepath : " , tourItemData.responseFilename); //workaround for the new bug - commenting the next line
//tourItemData.responseFilename = toursFolder.fileUrl(itemInfo.itemId + "/mapTourInfo.json");
tourItemData.itemInfo = itemInfo;
tourItemData.downloadItemData(itemInfo);
onRequestStatusChanged: { switch (requestStatus) { case Enums.PortalRequestStatusInProgress:
break;
case Enums.PortalRequestStatusCompleted:
console.log(responseFilename);
//stackView.showTour(itemInfo);
stackView.showTour(JSON.parse(tourItemData.responseText));
break;
case Enums.PortalRequestStatusErrored:
console.log("requestError.code: ", requestError.code); console.log("requestError.message: ", requestError.message); console.log("requestError.details: ", requestError.details); break;
FileFolder { id: toursFolder
path: "~/ArcGIS/MapTours2"
Here is the console output below:
Starting C:\Qt\Qt5.4.0\5.4\msvc2013_64_opengl\bin\qmlscene.exe...
file:///C:/Users/tkoka/Desktop/AppStudio/app.qml:3 Type StartPage unavailable
file:///C:/Users/tkoka/Desktop/AppStudio/template/StartPage.qml:16 plugin cannot be loaded for module "ArcGIS.Runtime": Cannot load library C:/Qt/Qt5.4.0/5.4/msvc2013_64_opengl/qml/ArcGIS/Runtime/ArcGISRuntimePlugin.dll: The specified module could not be found.
C:\Qt\Qt5.4.0\5.4\msvc2013_64_opengl\bin\qmlscene.exe exited with code -1
