I have a survey built in Survey123 Connect 3.7.62 that was working just fine until I tried to update a field. I can delete the whole row with the problem field and re-publish without issue, and I was able to make a new survey copying the whole .xlsx file including the problem field in it and publish without issue, but I cannot get the existing survey to publish with that field. It gets stuck on "Adding Fields to surveyPoint: 1" under status "Information". When I look at the table data on AGO, the new fields have been added, but the publishing never completes in Connect. I can send the diagnostic log, in case that can help pinpoint what's failing, but prefer not to post it publicly - the error message during publishing is "[AppStudio@11205 category="default" filename="PublishSurvey.qml" line="533"] qrc:/qml/Connect/PublishSurvey.qml:533: TypeError: Value is undefined and could not be converted to an object".
Any help is very much appreciated. Thank you!
