I am wondering if it is possible to add an Overlay to a geometry, but either keep that underlying Geometry's label, or add a label to the overlay. Since I am adding an overlay based on a unique attribute of a layer, I need to show the ID of that underlying layer.
I use this code to add an overlay, but I really need to either retain the underlying label, or better yet, add a label overlay too. Any Ideas?
Geometry MergedMATGeometries <SPAN class="operator token">=</SPAN> FeatureServiceManagement<SPAN class="punctuation token">.</SPAN><SPAN class="token function">MergeSearchedGeometry</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"LayerName"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"AttributeName"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"AttributeValue"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
CIMStroke solid <SPAN class="operator token">=</SPAN> SymbolFactory<SPAN class="punctuation token">.</SPAN>Instance<SPAN class="punctuation token">.</SPAN><SPAN class="token function">ConstructStroke</SPAN><SPAN class="punctuation token">(</SPAN>CIMColor<SPAN class="punctuation token">.</SPAN><SPAN class="token function">CreateRGBColor</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">255</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">50.0</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">1.0</SPAN><SPAN class="punctuation token">,</SPAN> SimpleLineStyle<SPAN class="punctuation token">.</SPAN>Solid<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
CIMColor RandomColor <SPAN class="operator token">=</SPAN> <SPAN class="token function">GetRandomColor</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
IDisposable disp <SPAN class="operator token">=</SPAN> mapView<SPAN class="punctuation token">.</SPAN><SPAN class="token function">AddOverlay</SPAN><SPAN class="punctuation token">(</SPAN>MergedMATGeometries<SPAN class="punctuation token">,</SPAN>
SymbolFactory<SPAN class="punctuation token">.</SPAN>Instance<SPAN class="punctuation token">.</SPAN><SPAN class="token function">ConstructPolygonSymbol</SPAN><SPAN class="punctuation token">(</SPAN>RandomColor<SPAN class="punctuation token">,</SPAN> SimpleFillStyle<SPAN class="punctuation token">.</SPAN>Solid<SPAN class="punctuation token">,</SPAN>
solid<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">MakeSymbolReference</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//I need to add a label to the above AddOverlay, </SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
