I use data from two different sources. They have different spatial reference:
Cadastral data
PROJCS["ETRS89_Poland_CS92",GEOGCS["GCS_ETRS_1989",DATUM["D_ETRS_1989",SPHEROID["GRS_1980",6378137.0,298.257222101]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Transverse_Mercator"],PARAMETER["false_easting",500000.0],PARAMETER["false_northing",-5300000.0],PARAMETER["central_meridian",19.0],PARAMETER["scale_factor",0.9993],PARAMETER["latitude_of_origin",0.0],UNIT["Meter",1.0]]
Administrative position
PROJCS["ETRS89 / Poland CS92", GEOGCS["ETRS89", DATUM["European Terrestrial Reference System 1989", SPHEROID["GRS 1980", 6378137.0, 298.257222101], TOWGS84[0,0,0]], PRIMEM["Greenwich", 0.0], UNIT["Decimal Degree", 0.017453292519943295]], PROJECTION["Transverse_Mercator"], PARAMETER["latitude_of_origin", 0.0], PARAMETER["central_meridian", 18.999999999999982], PARAMETER["scale_factor", 0.9993], PARAMETER["false_easting", 500000.0], PARAMETER["false_northing", -5300000.0], UNIT["Meter", 1.0], AUTHORITY["EPSG", 2180]]
When I display those layers in the ArcMap 10.3.1 they don't overlap. How can I change it? I tried to use project tool but didn't work - the layer "cadastral data" doesn't display.
