I'm in need of some help. I have a file with a attribute field named SPCOMP and I need to separate it out. The SPCOMP field is populated with a string such as "Sb 90Bf 10" or Pj 80Sb 20" or Pj 40Bw 40Sb 20" etc. I'm trying to write a code using the field calculator in VB
script that will search through the SPCOMP field for "Sb 90" and populate another field SB with 90 or search for "Sb 60" and put 60
in the SB field. My code is:
Dim SB
if [SPCOMP] = "%Sb 90%" Then
SB = 90
elseif [SPCOMP] = "%Sb 60%" Then
SB = 60
else
SB = 1
end if
When I run this it will populate the SB field with 1 so I think my mistake is with the wildcard search? Can anyone offer suggestions on this or where I could find answers? I'm using ArcGIS advanced 10.3.
