Hello. I have a data processing model in ModelBuilder that makes heavy use of the "Get field value" tool. I need to iterate the model over many tables in a geodatabase. When I do this, I do not get the correct values on the output based on the Get field - for each input table, the output is the same each time. I think what is happening is the Get values are being held over from the first run of the model and not being picked up again with values from the next table as the model re-runs. I have also had the same issue trying to use batch on the model. Is there some command I can add to the end of the model that will clear the Get values from the system memory? This is in Desktop 10.4.
