HI, I have a problem in AppStudio for arcgis. I created an application to add a feature in feature service when a button is pressed, I found a very simple way to do this in the help of arcgis but when run the project don´t save the feature
I leave here the code used whitout mistakes, but not add the feature.
I only need capture the current location for the feature to add.
someone can help me
thanks
App { id: app
width: 640
height: 480
Rectangle
{ id: titleRect
anchors
{ left: parent.left
right: parent.right
top: parent.top
height: titleText.paintedHeight + titleText.anchors.margins * 2
color: app.info.propertyValue("titleBackgroundColor", "darkblue") }
Map { id: map
Envelope { id: envelopeInitalExtent
xMax: -13630134.691272736
yMax: 4554320.7069897875
xMin: -13647294.804122735
yMin: 4535211.44991852
spatialReference: mainMap.spatialReference
positionDisplay { id: positionDisplay
zoomScale: 200000
mode: Enums.AutoPanModeDefault
positionSource: PositionSource { id: positionSource
anchors { left: parent.left
right: parent.right
top: titleRect.bottom
bottom: parent.bottom
onStatusChanged: { if(map.status === Enums.MapStatusReady) { graphicsLayer.renderingMode = Enums.RenderingModeStatic;
addLayer(graphicsLayer);
ArcGISTiledMapServiceLayer { url: "http://services.arcgisonline.com/ArcGIS/rest/services/Canvas/World_Light_Gray_Base/MapServer"
ArcGISDynamicMapServiceLayer
{ id: demoDynamicMapService
url: "https://gis1041.sbx.mx:6443/arcgis/rest/services/Boton_Emergencia/BTN_Emerg/MapServer"
GeodatabaseFeatureServiceTable
{ id: featureServiceTable
url: "https://gis1041.sbx.mx:6443/arcgis/rest/services/Boton_Emergencia/BTN_Emerg/FeatureServer/0"
FeatureLayer
{ id: featureLayer
featureTable: featureServiceTable
Button { id: showPosition
text: "Capture Location"
width: addLocationPoint.width
enabled: mainMap.status === Enums.MapStatusReady
onClicked: { positionSource.active = true;
positionDisplay.mode = Enums.AutoPanModeDefault
var featureJson = { geometry: { x: positionDisplay.mapPoint.x,
y: positionDisplay.mapPoint.y,
attributes: { desc: "ABC456"
if (featureServiceTable.featureTableStatus === Enums.FeatureTableStatusInitialized) { featureServiceTable.addFeature(featureJson)
Button { id: hidePosition
text: "hide Location"
// anchors.horizontalCenter: parent.horizontalCenter
anchors.verticalCenter: parent.verticalCenter
onClicked: { positionSource.active = false;
