The survey I am creating requires 3 geopoint questions (collecting Lat/Long) of Location of Incident, Beginning point and Ending point of Discharge. I know you can use a repeat for multiple geopoint of the same question. What would be the recommended approach for this issue? A clunky way is wording the question, "Geolocate: Incident/Beginning/Ending point" and have a text entry to describe each geopoint. Can you use conditions and relevant inside the repeat group? Also, originally requested to have select one choices of N/A, Same as Location of Incident, add Geopoint for beginning and ending points, which is easy to do with multiple geopoints. Thanks!
