I have a feature(not hosted) in sql, doing testing with some data, the report tab and using the report api with python have no problem generating a report for one selection. Now I insert 90,000 record in the feature and then go to feature tab in web123 and select one record and try to generate the report, after a 1 minute says: " error occurred when query data form the feature". I go to my arcserver manager and found in the log the error that the feature have a timeout.
I have the feature with query enable. I can try to change the timeout time that is 1 minute and also put more instance but when the feature continues to growing, I will have to continue increasing this parameters? What is recommended to handle this?
thanks
