i use the addshapefile widget to add a widget to the map and then I tried to run a query to capture features of the shapefile that intercept the buffer around a line segment. However I get the message:
"FeatureLayer::selectFeatures - query contains one or more unsupported parameters".
Can the feature layer from the shapefile be used for query?
Thank you.
myfeaturelayer is the feature layer from the shapefile created from:
arrayUtils.forEach(featureCollection.layers, lang.hitch(this, function (layer) {
var infoTemplate = new InfoTemplate("Details", "${*}");
var featureLayer = new FeatureLayer(layer, {
infoTemplate: infoTemplate
});Buffer Widget:
The resultEvent is the geometry of a line
