Good Day,
I want to create a very basic app login hence I am looking for alternatives to OAuth, Token Auth etc. I just want a login page with a Username and Password. That's it, nothing else. Therefore, I decided to use Secure Storage with the thought process being.......a username and password is stored by a user initially. When the user opens the app in the future, they enter the same user name and password and hit 'Login'. So, this login checks the keychain to ensure the password is correct and then allows access to the app by opening a new window.
I modified the Secure Storage code to include a 'Login' Button however nothing happens when I hit Login. Therefore, I assume that the problem lies with the Login button. Can I be guided on how to fix this? Thank you. Below is the code:
import QtQuick 2.7
import QtQuick.Layouts 1.1
import QtQuick.Controls 2.1
import QtQuick.Controls.Material 2.1
import QtGraphicalEffects 1.0
import QtQuick.Dialogs 1.2
import QtQuick.Window 2.1
import ArcGIS.AppFramework 1.0
import ArcGIS.AppFramework.Controls 1.0
//import Esri.ArcGISRuntime 100.1
import ArcGIS.AppFramework.SecureStorage 1.0
import "controls" as Controls
App { id: app
width: 400
height: 750
function units(value) { return AppFramework.displayScaleFactor * value
property real scaleFactor: AppFramework.displayScaleFactor
property int baseFontSize : app.info.propertyValue("baseFontSize", 15 * scaleFactor) + (isSmallScreen ? 0 : 3) property bool isSmallScreen: (width || height) < units(400)
property string insertSuccessMessage: qsTr ("Inserted into Keychain") property string removeSuccessMessage: qsTr ("Removed from Keychain") property string failMessage:qsTr("Something Went Wrong") property color successColor: Material.color(Material.Teal)
property color errorColor: Material.color(Material.DeepOrange)
Page { anchors.fill: parent
header: ToolBar{ id:header
width: parent.width
height: 50 * scaleFactor
Material.background: "#8f499c"
Controls.HeaderBar{} }
// sample starts here ------------------------------------------------------------------
contentItem: Rectangle { anchors.top:header.bottom
ColumnLayout { spacing: 5 * scaleFactor
anchors.horizontalCenter: parent.horizontalCenter
// Insert key in this text field
TextField { id: username
placeholderText: "Username"
echoMode: passwordVisible.checked === true ? TextInput.Normal: TextInput.PasswordEchoOnEdit
Material.accent: "#8f499c"
Layout.topMargin: 100 * scaleFactor
Layout.fillHeight: true
Layout.fillWidth: true
// Insert value in this text field
TextField { id: password
echoMode: passwordVisible.checked === true ? TextInput.Normal: TestInput.PasswordEchoonEdit
placeholderText: "Enter password"
//Click on the button to store key and value in the keychain
Button { id: saveButton
text: qsTr("Save Data to Keychain") onClicked: { SecureStorage.setValue(username.text, password.text)
Button { id: loginButton
text: qsTr ("Login") onClicked: { if(password.text === true) { var component = Qt.createComponent("Child.qml") var window = component.createObject (root)
window.show ()
