Hi Guys,
I have a button in a dockpane to add one graphic overlay on the map view based on the provided geometry like below code snippet.
I call RemoveDrawnGraphic method before AddGraphics is being called so that I will only have one graphic overlay.
Some how, from third time button click of drawing graphic overlay, RemoveDrawnGraphic method is not working anymore, no more overlay removal is performed.
This is happening in arcgis pro 2.5, as long as I remembered, I didn't encountered it in 2.4.x .(I guessed)
Or my code has some issue? Uma Harano ?
<SPAN class="keyword token">private</SPAN> <SPAN class="keyword token">async</SPAN> Task <SPAN class="token function">AddGraphics</SPAN><SPAN class="punctuation token">(</SPAN>Geometry geometry<SPAN class="punctuation token">)</SPAN>
<SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">await</SPAN> QueuedTask<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Run</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">=</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>polylineSymbol <SPAN class="operator token">=</SPAN> SymbolFactory<SPAN class="punctuation token">.</SPAN>Instance<SPAN class="punctuation token">.</SPAN><SPAN class="token function">ConstructLineSymbol</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>polylineGraphic <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">CIMLineGraphic</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>polylineGraphic<SPAN class="punctuation token">.</SPAN>Line <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">(</SPAN>Polyline<SPAN class="punctuation token">)</SPAN>geometry<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>polylineGraphic<SPAN class="punctuation token">.</SPAN>Symbol <SPAN class="operator token">=</SPAN> polylineSymbol<SPAN class="punctuation token">.</SPAN><SPAN class="token function">MakeSymbolReference</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>CurrentGraphic <SPAN class="operator token">=</SPAN> MapView<SPAN class="punctuation token">.</SPAN>Active<SPAN class="punctuation token">.</SPAN><SPAN class="token function">AddOverlay</SPAN><SPAN class="punctuation token">(</SPAN>polylineGraphic<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">private</SPAN> <SPAN class="keyword token">async</SPAN> Task <SPAN class="token function">RemoveDrawnGraphics</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">var</SPAN> ps <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">ProgressorSource</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
ps<SPAN class="punctuation token">.</SPAN>Message <SPAN class="operator token">=</SPAN> <SPAN class="string token">"Removing overlay graphic to keep latest overlay only"</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>CurrentGraphic <SPAN class="operator token">!=</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>polylineSymbol <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>polylineGraphic <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>CurrentGraphic<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Dispose</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>CurrentGraphic <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">await</SPAN> QueuedTask<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Run</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">=</SPAN><SPAN class="operator token">></SPAN> Task<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Delay</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">1000</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">Wait</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> ps<SPAN class="punctuation token">.</SPAN>Progressor<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">//Lets give garbage collector 1 sec, seem overlay does not disappear adhoc</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
