I am trying to find a specific field name in layers in a current working MXD, but I'm having problems getting it right. The overall goal is to loop through layers in an MXD and set a definition query based on a user input (string type). The script runs without any errors, but no definition query is set.
Could it be because the type returned by the arcpy.Describe().fields function is Unicode?
Any help or advice is greatly appreciated!
<SPAN class="keyword token">import</SPAN> arcpy
<SPAN class="comment token">#User input as 'String' type</SPAN>
feederID <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>GetParameterAsText<SPAN class="punctuation token">(</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">#Variables</SPAN>
mxd <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>mapping<SPAN class="punctuation token">.</SPAN>MapDocument<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"CURRENT"</SPAN><SPAN class="punctuation token">)</SPAN>
df <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>mapping<SPAN class="punctuation token">.</SPAN>ListDataFrames<SPAN class="punctuation token">(</SPAN>mxd<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="comment token">#Set definition query to user set parameters</SPAN>
<SPAN class="keyword token">for</SPAN> lyr <SPAN class="keyword token">in</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>mapping<SPAN class="punctuation token">.</SPAN>ListLayers<SPAN class="punctuation token">(</SPAN>mxd<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> df<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
fields <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>Describe<SPAN class="punctuation token">(</SPAN>lyr<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>fields
<SPAN class="keyword token">for</SPAN> f <SPAN class="keyword token">in</SPAN> fields<SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">if</SPAN> f<SPAN class="punctuation token">.</SPAN>Name <SPAN class="operator token">==</SPAN> <SPAN class="string token">"FEEDERID"</SPAN><SPAN class="punctuation token">:</SPAN>
lyr<SPAN class="punctuation token">.</SPAN>definitionQuery <SPAN class="operator token">=</SPAN> <SPAN class="string token">"""FEEDERID = """</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="string token">"'"</SPAN> <SPAN class="operator token">+</SPAN> str<SPAN class="punctuation token">(</SPAN>feederID<SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="string token">"'"</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>RefreshActiveView<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
