I have a select_multiple that has a list of birds to choose from. When I choose 'Other', it opens a following question using the relevant field. This setup follows: https://community.esri.com/groups/survey123/blog/2017/12/11/making-other-work-harder-in-survey123-results, but is adapted for a select_multiple. I then have a third field that is hidden that takes the answers from the previous fields and concatenates them. The concatenation is roughly as follows:
if(selected(${field_one}, 'Other'), if(count-selected(${field_one}) > 1, concat(${field_one}, ', ', ${field_two}, ${field_two}), ${field_one}).
It should read:
if (other is selected in the first field) then
if (there is more then the other selected in the first field) then
concatenate both fields and return
else
just return second field
else
just return first field
The issue is that if both fields are concatenated, the selection of other from the first field will still be listed within the string. I can remove it during the concatenation by removing the last 6 characters of the substring, but that requires it to be selected last from field one when the user is filling out the survey.
Is there anyway to force the order the answers are selected or another way to concatenate the results?
