Hello, I am working on a versioned SDE which will get reconciled to the default SDE hosted in a different office location. Currently, there are a lot of topological errors that I will need to fix such as snapping nodes to lines so I will need to have the validation inspector to edit. When I tried to create new topology for feature dataset, it said “ the selected feature dataset doesn’t contain any feature class which can participant in a topology”. I am not sure what could cause that as there are various points, lines and polygons under the feature dataset. Also, I can't unregister as versioned as I am not the data owner. Can anyone here suggest what I could look into?
