Hi
I've followed the steps outlined here to debug the template in QT Creator (Community Edition)
Debug JavaScript in Qt Creator—AppStudio for ArcGIS | ArcGIS
When trying to run the debug on the out of the box survey 123 template, I get the following errors from Qt Creator
13:58:21: Debugging starts
13:58:21: Starting C:\Qt\5.10.0\msvc2017_64\bin\qmlscene.exe C:/Users/myuser/ArcGIS/AppStudio/Apps/7d2b8e83c9e44cd4b9e511757e9849d5/Survey123Connect.qml "-qmljsdebugger=port:51225,block,services:DebugMessages,QmlDebugger,V8Debugger,QmlInspector"
QML Debugger: Waiting for connection on port 51225...
ArcGIS.AppFramework.Plugin: void __cdecl AppFrameworkPlugin::registerTypes(const char *) ArcGIS.AppFramework
ArcGIS.AppFramework.Plugin: void __cdecl AppFrameworkPlugin::initializeEngine(class QQmlEngine *,const char *) ArcGIS.AppFramework
ArcGIS.AppFramework.Plugin: void __cdecl AppFrameworkPlugin::initializeEngine(class QQmlEngine *,const char *) Offline storage path: "C:\\Users\\myuser\AppData\\Local\\QtProject\\QtQmlViewer\\QML\\OfflineStorage"
ArcGIS.AppFramework.Plugin: void __cdecl AppFrameworkPlugin::initializeEngine(class QQmlEngine *,const char *) CoInitializeEx failed: -2147417850
ArcGIS.AppFramework.Plugin: void __cdecl AppFrameworkPlugin::initializeNetwork(void) Using system network proxy configuration
ArcGIS.AppFramework.Image: void __cdecl ImageProvider::initialize(class QQmlEngine *) QQmlEngine(0x79b7aff0f8)
ArcGIS.AppFramework.Image: __cdecl ImageProvider::ImageProvider(class QFlags<enum QQmlImageProviderBase::Flag>) QFlags()
Registering QML types: ArcGIS.AppFramework.Desktop
Initializing QML engine: ArcGIS.AppFramework.Desktop
ArcGIS.AppFramework.Sql.Projection: void __cdecl Proj4::initialize(void) PJ_VERSION: 493
ArcGIS.AppFramework.Sql.ST: class QString __cdecl ST_Projection::lookupDef(int) 4326 = "+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs"
file:///C:/Users/myuserArcGIS/AppStudio/Apps/7d2b8e83c9e44cd4b9e511757e9849d5/Survey123Connect.qml:19 Type ConnectApp unavailable
file:///C:/Users/myuser/ArcGIS/AppStudio/Apps/7d2b8e83c9e44cd4b9e511757e9849d5/Connect/ConnectApp.qml:214 Type TutorialsTab unavailable
file:///C:/Users/myuser/ArcGIS/AppStudio/Apps/7d2b8e83c9e44cd4b9e511757e9849d5/Connect/TutorialsTab.qml:19 plugin cannot be loaded for module "QtWebView": Cannot load library C:\Qt\5.10.0\msvc2017_64\qml\QtWebView\declarative_webview.dll: Th
e specified module could not be found.
13:58:23: Debugging has finished
13:52:41: Debugging has finished
