Hello everyone,
I´m dealing with a very simple issue but unfortunately cannot find any solution. I´m trying to import multiple shapefiles into a file geodatabase using the “Feature Class to geodatabase (multiple)” tool. I´m getting the error: 000732 (Input features: Dataset does not exist or is not supported) (no matter if in ArcMap or ArcCatalog). The dataset comes from the OSM-geodata platform Geofabrik.de. With other shp-files it works just fine. Also when I try the export option after loading the shp-file(s) into the Desktop map window it shows the same error. The SHP aren´t damaged anyway and
don´t include No Data values but I don´t think this will be the problem. Any ideas how to solve this?
