(2.4.0 ArcGIS Pro)
I don't see any way to modify the scoring when using create locator; is this by design? It appears that minimum match scores are set in the project. What about published locators? Can minimum match scores be set once a locator is shared?
If a multi-role locator is created, is there a way to have different scoring values for each role? For example, I'd like the address points to only consider a 95% score as a match, where as a street address role would be more forgiving, along the lines of 80 or 85%.
Shana Britt
Eric Anderson
